Can I add color to High-Temp V2 resin
Good morning, @Whippersnapper -
Thank you for the question. We have a support article on adding dye to resin which notes that any additive may cause issues with your resin, but that users have been able to use alcohol dyes to get colored resin.
Thanks!
-Jen
I had some amount of luck dyeing a handful of hi-temp parts yellow using orange alcohol (tangerine - 34), the results were not quite yellow but not quite orange.
I also tried dyeing white resin parts using green (shamrock - 55) results were far more mixed some were quite good while others were very streaky (geometry dependant)
