I’m not sure how doable this is, but would it be possible to modify the form1 or to make a version that prints from the top instead? Meaning the laser shoots down into a tub of resin from the top, curing a thin layer of resin as the base slowly moves down? This way you won’t need the peeling mechanism, resulting in cleaner prints, faster prints, less supports. Also, you can pretty much use anything as a resin tank, and don’t have to worry about the silicone coating, or optical quality of the tank, etc.
In theory, all you would need to do is, flip the form 1, disconnect the peeling mechanism, somehow hot-wire the z axis to move in the opposite direction, invert and modify the base a little, and make a simple frame to hold the printer in that position and the tub of resin.
What do you guys think?
