Sudden failure D:
Hi there! I’ve been printing figures on my form2, and rather out of the blue, they started failing.
I was using the same preform that i’d been using and everything, but they just stopped coming out.
I got a new tank in case mine was wearing out, or was damaged and that didn’t fix anything. Any prints i tired still failed.
I changed the Z setting on the form2 and a small print worked finally, when i went to make a bigger one, it failed.
Any advice on what to adjust next? I’m using the clear resin.
Can you give us a bit more information about how these are failing? Using a new tank is a great first troubleshooting step but there could be a few other things going on. If you could upload pictures of the print failures and possibly the orientation of the parts in PreForm, that would be a big help.
