Hi T78 - I would absolutely cut that piece in half (2 shorter L-shape parts), just to the side of the PP opening… the panel seems to be pretty thick there, so you could make a joint fairly easily. If you make the joint with some play, you should be able to glue it together with the front faces flush; do THAT right and then finish and paint it (if necessary), and it could look really good, good enough that noone would know you printed it in two parts.
Yes, that’s some work, but then the build volume is small in comparison to the part, and, as you rightly note, otherwise the results will be unusable. Well, maybe not unusable, if you put some work in, but I think in total you’ll get better results in a shorter time with less effort if you cut the part - if the part is stood up, as is your only choice to print in one piece, you will, I think, get the side closest to the base approx. 1mm bigger in x- and y-dimensions than the side higher up.
By the way: I’ve printed the part I showed with measurements up top out a few more times since I last wrote: printing at just 5 degrees flat angle (only in one axis), I have a super flat part, correct to within ~0,1mm in all dimensions, as well as a nice finish (without any extra work):
The width of the printed part varies by only about 0,04-0,05mm - from left to right it gets smaller.
Therefore I’m pretty sure that your part can also be printed nicely, BUT ONLY IF YOU CUT IT IN TWO, so that you can keep the left to right axis to within a few degrees of the base plate - then you can put all the supports on the bottom surface (perhaps even just the edges), which should be reasonably easy to sand, and must be less critical anyway. (Perhaps, alternatively, stand the 2 parts up so as to enable the supports on the inside, but I think that is probably more trouble than it’s worth).
In addition, hollowing it out will reduce stresses while printing… you can give it a relatively thick wall, like 3 or even 4mm I think, but not completely solid. Perhaps others also have some good ideas (also corrections to my ideas/comments are no problem).
Anyway, I can’t do any of this on an .STL file myself… if you upload a solid model (like STEP or SolidWorks) I could show you what I mean a bit better. (In fact, I actually meant the part you were originally trying to print, the Dispenser B13 part, when I first offered to show you what I mean, but I think it’s all the same principle, really).
