[Solved] Rigid 10k post-cure regime with Form 4 and Cure V2
The Rigid 10k TDS gives post-cure profiles for different mechanical and thermal properties. However, the example post-cure regimes are only provided for Form 3 and Form Cure V1. Given the huge difference in the initial post-cure for Rigid 10k V1.1 of 60 minutes at 70 C for Cure V1 and pre-heat for 3 minutes at 80 °C with the lights off then post-cure for 7 minutes at 80 °C for the Cure V2, what subsequent thermal post-cure is required to get equivalent changes in the heat deflection temperature and mechanical properties?
Hi! Thanks for the question!
For the thermal cure, you can follow the original schedule of 125min at 90°C (without UV curing). The thermal post-curing profile was also added to the Form Cure V2 in the firmware version 1.3.0 - you can select it under the Rigid 10K Resin profile.
