Form2 software locked up mid build. Is it possible to continue a build?
Software crash, can a build be continued mid-build
Randy_Cohen
#2
You mean Preform on your PC locked up? That doesn’t control the printer once the job has started. If you mean the printer firmware locked up, then no, there is no way to recover/resume the print. You’ll have to powr cycle the printer to get it to recover. And to be on the safe side, I’d recommend you remove the build plate with any partially printed material on it before you reset the printer.
system
#3
