Slow floating resin
We recently received a new Form 4L. Since the initial resin loading, the printer repeatedly reports that resin is slowly flowing out of the left cartridge. When I moved the cartridge to the right slot, the issue disappeared. However, inserting a new cartridge on the left side causes the error to reappear.
Error code: 1.9.11.
Good Morning.
Thank you for writing us in the forums. I am sorry to hear you are experiencing a slow flow rate error. Which resin are you seeing this error with? Please see the below steps:
  1. Check the bite valve on the underside of the cartridge to make sure it opens when squeezed.
  2. Shake the resin cartridge to ensure that the resin is mixed thoroughly.
  3. Check the temperature around the printer and your resin storage area. The recommended operating temperature range for Form 4L generation printers is 18–28 °C (64–82 °F).
  4. Try another resin cartridge if any are available.
  5. Reboot your printer.
  6. Ensure that your printer’s firmware is up to date. If the printer’s firmware is already up to date, manually reinstall the latest firmware package.
  7. Inspect and reseat the left cartridge floor cables. Follow the instructions in the repair guide Replacing the Form 4L cartridge floor to Step 2: Disconnect the cartridge floor cables.
Hi @KCasey ,
We are using ESD Resin.
  1. It cannot be the bite valve, as the issue occurs with every new cartridge I insert on the left side.
  2. The room where both the printer and the cartridges are located is around 20–22 °C.
  3. Trying a different resin cartridge and restarting the printer did not change anything.
  4. The firmware updates automatically, so that should be fine.
  5. I will check the cables after the weekend.
Good Morning,
I would still check that the firmware is updated by doing so manually. The printer may say it is up to date, but could be a few versions behind. We would still want you to do a manual update of the firmware by following this guide.
Hello @KCasey the printer has been updated and the problem actually seems to be resolved. Thank you very much for your help.
Good Morning. I am glad I was able to assist and you are up and printing!
I encountered the slow-flowing resin issue again. However, I then turned the resin bottle upside down and gently kneaded the valve, as it seemed to be clogged. After that, the error message did not appear again for this particular bottle.
