When I print large models in high res that has thick parts, I notice the cloudiness of PDMS occur faster then printer can finish the job. That often result in failed print. At some point I had an idea that I would like to change the vat or filter the resin in vat in the middle of the print, but it’s not possible because the platform remains lowered in the vat when you pause.
To me it seems it would be helpful to implement the function that would pause the print and lift the platform allowing replacement of the vat and/or resin, and then continuing to finishing the print.
Is it possible to implement in next update of Preform?
Thanks!
