Separating Agent
I print Orthodontic models with Draft Resin V2. What is the best Separating Agent? Currently I am using Divorce (coating the model 3 times). After placing the brackets on the model then making the Indirect Boning trays while pulling the tray from the model some of the adhesive is on the bracket pad and some of the adhesive stays on the model. It’s not every bracket, some brackets the adhesive stays on the bracket pad perfect.
Any suggestions?
Hi @backusortho,
I was able to find some recommendations for separating agents on our Manufacturing Hawley Retainers guide. Although this may not correspond exactly with your particular application, this might be a good place to start. If you’d like more specific advice, please feel free to get in touch with Support so that a member of our Dental team could look this over.
