Typical issue on a Form2 printer.
Make sure that the roller bearings of the resin tank frame are always running free!!!
Otherwise you will have problems with the proper positioning of the resin tank ![]()
as you can see the bearing on this printer didnāt work as they should so the whole frame is not sliding it is more or less āgrindingā over the bearings.
Best
Peter
