I’m presenting this as a suggestion to FL for research, rather than directly to the users to try themselves. I always feel a little guilty doing the latter because I know Formlabs isn’t very “open source” about hacks and user-based improvements, so I’m giving you the right of first refusal, I guess.
I read user forums about several different resin printers and it seems this is emerging as a thing:
Non-Stick Film for Resin Printers
I can’t imagine it would be rocket science for Formlabs to eschew the PDMS of the resin tray and add this foil instead, doing one of two things:
- Installing thicker clear acrylic to equal the height of the original PDMS print surface, or
- keep the same acrylic and use the tray chip to tell the Form printer to lower the buildplate more than for a PDMS tray.
My first thought was to just slap the film onto the PDMS of an existing tray, but isn’t the point of silicone that nothing sticks to it? If the softness of the silicone is needed to provide wiggle room for the print process, there are optically-clear urethane rubbers, to which the foil (and anything else not nailed down) would surely bind. Certainly any discrepancies of refraction index in all these alternatives can’t be fatal over a distance of 1 - 2 mm?
I do plan to explore these options someday, but I thought maybe it’s in FL’s interests to pursue them under their own auspices, so they, rather than some meddling user, could be the leading-edge heroes!
