Installed PreForm 2.14.0 and the latest firmware.
Cleaned out the resin tank I use for Gray resin, and set a print starting. It’s been filling for 10-15 minutes, and it has filled over the “max fill” line on the tank ( pictures attached ) then it started printing.
Is it normal for the tank to fill this much? Is there a tank fill line adjustment I should be aware of?
