Resin spill on underside of tank film
Hi all I moved recently and in the process one of my resin tanks spilled. The resin is all self contained in the tank / tank case. The issue is that some resin has gotten on the underside of the tank film. If I clean it very carefully can I continue using the tank or do I need to buy a new one?
Hi dylan_r,
You should be able to clean that area via our Inspecting and cleaning resin tanks (Form 3/Form 3B) (formlabs.com) steps, under where it mentions Cleaning the resin tank exterior.
If you’re running into issues while cleaning, you can create a support case with our support team with photos for further advice if you are not sure how to proceed.
