HI All,
I’m working with Rigid 10K on a 3L and having issues removing the 10K prints from the print bed. They have adhered phenomenally well to the plate and just want stick. The raft is just shattering into small pieces. Any advice for techniques/chemicals to remove the parts or just give it some more elbow grease?
Thanks!
maybe you could try adjusting your z-height from the printer’s menu to a higher value? (it’s on 3, i guess it should be on 3L too)
Thanks for the suggestion! Would this parameter need to be adjusted a little over time? A couple of weeks ago we were printing in Draft V2 and the raft removal was super easy.
Check here for instructions
You can go one step at a time so as not to go on the opposite side of prints falling off.
Hi @rauschjohn16,
Thanks for reaching out! In addition to the Z-axis adjustment that @agiorgitis mentioned, please also refer to the “Other methods” section of Removing parts from the build platform. This covers some additional techniques to get parts detached from the platform.
