I just got the printer. The fit and finish of the non-supported surfaces is pretty good, but the quality by the supports is pretty bad. I also notices some small holes that you can see right thru.
Hi Chris,
When there is a flat surface facing the platform it causes tearing of the first layers in the space between the supports. If you angle the surface as little as 6 degrees it allows the part to “grow” from the previous layers. That gives strength between supports. This is why the Auto-Orient feature chooses such crazy angles.
I used the Auto-Orient feature.
Cuss at it and click it again…
