Hello.
I am having problems with the surgical guides. When I print guides with holes for 3mm cylinders, many times the hole is covered with resin and cannot be used. I’ve tried changing angles but can’t find a way to get reproducible results. I attach photos to see the results I get. any ideas??
Hi @Salvadoroltra,
Sorry for the late reply to this post, but I wanted to make sure that you were able to get in touch with our Support Team to get this problem looked into. Please do submit a ticket if not and they will be sure to help!
Hi,
The problem was the autocorrector with Autodesk Fusion 360 that when used produced damage to the structure of the guide. If I don’t use the autocorrector it works perfectly.
Hi @Salvadoroltra,
That is good to know, thank you for sharing the fix!
