Is it possible to print directly on the build platform but have supports for overhangs (either rafted, mini-rafted or no rafts for the supports)?
I attempted to do this the other day, but each time I attempted to manually generate a support point for an overhang, it created a raft for the entire part.
Select “None” for raft type and then “Auto-Generate Selected” or add the supports manually with “Edit…”
What you might be seeing as a raft here is the “Z-Compression Correction”, which is used to ensure your part is more accurate in Z, as the first few layers tend to be compressed. You can turn this knob down to zero if you like,
Two scenarios where you’d like to print directly on the build platform with only user generated touchpoints:
A. Works as expected.
Change Advanced Settings (Z-Compression Correction or Early Layer Merge)
Manually generate support (Edit -> Apply)
B. Does not work as expected (Step 2 does not live update the settings)
Attempt to change Advanced Settings (Z-Compression Correction or Early Layer Merge)
Is this expected behavior? It seems unintuitive. If you create the touchpoints first, the only way I’ve been able to apply Advanced Settings edits is the following: you have to Edit Supports -> Generate a new touchpoint/delete one -> click Apply.
