I’d like if you could turn on the resin tank usage map on the build platform so I can see where I’ve printed the most (display the same image as in dashboard but on the build platform).
Also I’d like if you could add a “preview function” which would draw almost transparent 3D model of a printer you are using in preform so it would be easier for a beginner to know where exactly print will be.
