I couldn’t find a way to rotate a part in the layout section of Preform software, once supprts are generated.
I’m not talking about changing the orientation of the part, I’m perfectly aware that I can re-orient a part and then I need to generate the supports again.
I’m just talking about rotating the part with its supports keeping it in the same position in space.
In the layout section I can easily move the parts in any direction but I can’t rotate them to optimize their position on the platform.
Am I missing something? Or simply this function is not available in the Preform software?
When you only rotate your part in the Z plane over in the ‘Orientation’ section, the supports are not regenerated.
got it! thank you
