Once auto-support generation is done, is there a way in preform to delete all supports to essentially start over?
Or is there a way to multi-select many supports at a time to delete in clusters?
Manually deleting extra supports (especially after auto-generation creates a hugely dense mesh of supports) can take 5-10 minutes.
For context, I am deleting auto-generated supports and observing the change (if any) in red-shading to determine how critical those supports were to the structure. Many auto-generated supports seem unnecessary, based on this type of analysis. This seems especially true for internal supports. Adding supports completely manually (or even just internal supports) seems to be a fairly fast process and can eliminate quite a bit of extra supports. This assumes that the redshading is relatively correct.
Any advice on this approach, and if there are short cuts that I am missing?
Thank you!
Jeff
PS here are some pics showing no supports, manual supports, auto-supports. Note the volume difference is 3X (it would be great to know if the manual approach is valid… the cost savings seems worthwhile)
