h
The resulotion of the print seems to be quite bad. I am using Color V1 resin. The support at three back is also completely fused to the coin. The middle of the coin is meant to spin and the tolerance on three design is large enough for that but the print is completely fused and doesn’t spin. It’s a new resin cartridge I opened but it’s been sitting in good storage for about 2 years. What can I do to fix this issue?
I know that Clear v1 Resin is an old resin update. I use it as Clear v4 and I have never even received such an error while using a 640-day tank.
Hello @akinloluakin!
Thanks for taking the time to post! Sorry to see you’re having some less than ideal print results!
I suspect the age of the resin is probably the primary culprit here. Can I also ask if you gave the cartridge a good long shake before printing? It’s possible after that much time a lot of the particulate in the color resin might have settled and is giving you these results.
