My wife accidentally threw out the power supply for my Form Cure. Can someone please (please!), take a look at their power supply and tell me the specs? Hopefully the brick will list what size the pin is that goes into the back of the Form Cure.
Thanks in advance!!!
it’s 24v 6A (144W) with a 5.5mm plug
Thank you so much! You’re a lifesaver!
Hi @Mark_Eberle,
Thanks for reaching out! If you are still in need of one, I would recommend getting in touch with our Support Team as they may be able to provide you with a replacement power supply.
