For those that received their Form1, can you tell me where the Form1 power adapter was located? Was it in the box with printer? Was there an ‘Accessories Kit’ box that came inside with the printer, and if so what was inside? Thanks for the info!
John,
You should be able to find the power adapter in a box at the bottom of the Form 1 printer box–underneath the second layer of plastic
Best,
Hello Martin, Thanks very much for the info, that sure seemed like the logical place for it!
I believe I know more about the specs of the PS than I would have ever dreamed of. For future reference on the specs of power supply for anyone needing, it is a Phihong 24v, 2.5a with -O+ polarity (5.5mm OD, 2.1mm ID for barrel connector).
Just wondering if the machine will still work ok if the power supply has only 2.0a.
The power requirement is 100–240 V, 1.5 A 50/60 Hz,60 W.
Sincerely,
Freddie Kwok
Would this be ok for the machine?
<img src="/uploads/formlabs/3711/890d3bc483811e9e.jpg" width=“281” height=“500”?>
Freddie Kwok
Would the laser within the Form 1 function properly with this ?
Sincerely,
Freddie Kwok
