Hi,
The orange lid/cover does not close properly on one side and there is gap
Any solution
Replacement of the cover. Hopefully under warranty.
If not, looks like a repair of the cover using an Acrylic solvent glue like MEK would be fairly straightforward - take the cover off, clamp the gapped area so it’s closed up tight, let a little solvent wick in to the seam using the solvent’s applicator, wait 24 hours, done.
Contact support, they will take care of you.
Bit risky part of using glue
Yes, it’s under warranty and ,i have contacted support and waiting for solution
Thanks for the solution
