Has anyone come up with a goo sequence of tests and parts to print to dial in open material settings?
find a formlabs equivalent material and start from there making adjustments until you reach the similar properties of the resin you are using.
I have done that. I am more concerned with the workflow since there are a lot of settings to be adjusted. I dialed in my size correction factors and now I’m messing with different exposures, but I think there should be a more specific workflow to follow. Should offset, correction factor, or exposures be dialed in first? And what parts can you print to achieve this and measure and correct the settings?
I agree, the available knowledge out there is extremely limited. I’m going to go through this process myself soon…will probably document what I find along the way so the knowledge is shared.
