DO NOT USE THIS RESIN.
THIS IS WHAT IT DID TO A BRAND NEW TANK.
I was advised to use 0.05 setting, grey, but to try other settings too, so I thought’hey, it’s got a white filler, let’s use the white setting’.
Looked good for 1st hour or so building supports, when I noticed that the print had become completely detached from the base plate - not good. When I removed the plate and tank 2 things stood out - the white filler had almost completely settled from the resin, and the resin that was cured was extremely brittle (and stuck rock solid to the rubber on my brand new tank - which is now ruined as it tore several chunks out).
As you can see from the yellowing, not only did the resin that was under immediate exposure cure - so did the rest of the resin in the tank as it is now very yellow in colouration compared to the clear resin prior to adding the filler.
Now even if the white setting is not suitable for this material, the separation of the filler from the resin within a 3 hour period is completely unacceptable.
I shall be attempting a refund and compensation from spotamaterials, can’t say I expect much luck though.
