The new base design in 2.14.0. seem like they are designed to waste of resin. The raised wall height doesn’t not scale with the base thickness and creates a lot of wasted material, especial if you have multiple small parts.
I run a small studio and I am quite caution about resin use. At 15 cents per ml just for standard resin, every bit counts. Even in the older version of preform I found the base thickness to be excessive and a waste of material. I have run my prints with the minimum base thickness of 1.0mm and height above base of 3.5mm. Not only does this save on resin, it saves on print time as well. With over 100 prints, none have failed under those settings.
The file I am printing now measured out at 13.27ml under the older version of Preform, and now with 2.14.0 it is measuring at 19.37ml. Changing the base thickness and height above base to the minimums has a negligible effect on the resin use, it only lowers by 0.7ml. I’m an not sure if the measurement difference is due to a new method of resin calculation or the the new bases, I am guessing the later. What it looks like on the surface is under 2.14 this specific model cost me and extra dollar in wasted material. Factored over multiple prints it is a huge loss. Formlabs please fix this.
