So all of a sudden today my Form 3 + is making a loud squeak that it wasn’t making before. I’m used to the sound it makes when the print bed fully rises between layers, but now it’s making this loud annoying squeak right before that. Is there something I can do to stop that? Is this indicative of something wrong? See vid below.
That’s a new one, my 3B+ doesn’t sound like that.
Check inside whether you see any area scratched. looks like there is a spot where it scratches when the LPU passed by
I had tanks making that noise. Only reseating the tank helped. You can also clean the rollers.
Mine was doing the same. I cleaned and lubricated the x-axis lead screw and all screeching went away. There’s reference to routine maintenance in the following: https://media.formlabs.com/m/5a3f3cadc639b857/original/-ENUS-Form-3-Manual.pdf
I’ll take a look, thanks
I’ll give that a try. Hopefully it’s just the tank, I’ve only had this thing for a month.
thanks! Did you use lithium grease for screw?
Yep…lithium grease.
