Hi all,
I am very curious how the form1 printer will handle polygon objects made up of multiple intersecting pieces. The terminology can vary between software, but in the software I use, combining more than one polygon object creates a new single object, with multiple “shells”. This can be a really great technique to keep certain parts separate for editing.
I have had mixed results printing objects on Shapeways with multiple intersecting shells. After a lot of back and forth it seemed like the main problem was specifically when faces from the intersecting shells touched in way where the normals on each shells touching faces were pointing in the opposite direction.
When I asked about printing polygon objects with multiple intersecting shells at the Inside 3d printing expo, I was told that the form1 will not support this.
However, reading on the FAQs here I found the following that is giving me hope that this is possible after all.
In the support section, it reads as if the support structures are combined as intersecting shells of the main object you are printing:
Distance from Model
This value defines the distance between the support structure “tip” and your model. Since support structures are actually attached to the model, this value is negative. You can think of negative values defining how deeply the support tip is “embedded” in the model. Changing this value will affect the touch point size.
Also, in the designing for printability section it reads as if to say mutliple intersecting shells are OK, so long as they are combined into one object:
Use Single Body (or Mesh) Settings
If your final model is the combination of multiple sub-models, make sure to save it as a single body (or mesh) in your CAD package. Otherwise there may be some irregularities in your print if the intersecting layers of the sub-models are not correctly recognized by PreForm Software.
Can the Form1 print objects with multiple *intersecting* shells, are these considered ‘problem objects’?
Thanks!
readyGo
