My Form2 is now throwing missing tray error. It is a brand-new tray with probably 2 prints done it. New Resin tank too. I have removed the tray and re-inserted it several times. I also powered off the printer too…no joy there. Anybody got any answers on this. I am out the water with this, is this the same issue seen before as broken pins?
Thanks Les Davis
The error on the dashboard says tank Cartridge mismatch but the printer says
this is what I have used since I got my form2 several years ago.
Thank you Les Davis
There is one possible situation: when you order material, look carefully at the requirements below. on the bottom right of the web page (I am having a similar problem) . There are two kinds of resin tanks and some materials require the LT tank. Seeing the icon above in your post answers one of my questions, that is, ‘will a standard resin tank print when an LT resin tank is reccommended or required’ -I guess it certainly is required -that could be your issue.
Hi @Phantom48,
Sorry for the late reply, but if you haven’t already opened a ticket with our Support Team, they can assist you with this!
