Minimum thickness to prevent my piece from bending after curing
Hello Goodnight. I have a doubt and consultation.
I put a rectangle out of its interior. Once printed on my form labs, with standard resin and its corresponding curing.
What minimum thickness can I design my “empty rectangle” so that in time the looks do not end up having a “Curve” effect?
It turns out that it has been designed to 0.9mm of wall … but it ends … curving … very little … but it curves or doubles.
What minimum thickness, do you advise me? I have to play with the minimum, I do modeling.
A cordial greeting.
Hi SPSpain,
I think that you used a language translator? The question is not clear.
What I think you are asking is about minimum wall thickness as related to post printing distortion? Be sure to research plastic part design online. Also, FormLabs provides some guidelines:
Tem
