Lubricate Wiper
Hi,
The wiper of my form2 squeak. Is it possible to lubricate ?
And with wich oil ?
Thanks in advance.
With a brand new tank, the wiper will have a bit of resistance the first few times it goes across. Once your tank is filled with a bit of resin, that will be sufficient to lubricate the wiper and there shouldn’t be any more squeaking.
Thanks for the reply.
But the “squeak” don’t come from the tank. It comùe from the base of the wipe.
I would check that the wiper is seated properly and not rubbing on the case of the printer. I’ve had a few times where the wiper was kind of half installed. It worked fine but was rubbing on the case.
Thanks again, But I removed the wipe and his support squeak again.
