It is safe to use Form Cure to cure paper towel and nitrile gloves post clean up?
Most common practices I’ve read online suggest leaving the cleaning material gloves/paper towel, etc, outside in the sun for a period of time before disposing of them safely in the trash. It is possible to safely speed up this process by curing the paper towel and nitrile gloves inside the Form Cure? Will the UV light burn the paper towel or melt the nitrile gloves?
If it is possible, what’s the recommended temperature/duration for curing paper towel/nitrile gloves?
i have curebox and the temps are not hot enough to burn anything but I have not tested nitrile gloves
