I there,
I’m looking forward on buying a Form2 3D printer and I’m wondering if I could print the enclosed model
The part is about 7-3/4 in x 6-7/8 in x 5 in
It’s a mutli part bodies, the cover and is supposed to be removable so I’m focusing on printing the body of the box because it seems to be the hardest part and I don’t want to invest in a product that just can’t do the job.
Thank you!
Coffre-V5-02|689x499
If that’s one specific piece then no the Form 2 cannot print that in one go because the build volume of a Form 2 is 5.7 × 5.7 × 6.9 in. Plus when you account for orientation and supports you probably couldn’t even fit exactly that so the part would have to be broken down. There are however larger print volume SLA style printers like the Peopoly Phenom https://peopoly.net/products/phenom that could print the object. Although with the coronavirus they have had to scale back production and shipment until cleared. There are however other options as well if you search. Best of luck.
Thank you very much for the answer.
