I am sorry, I know this is probably stupid question. I have looked around but I get overwhelmed with all the resources.
For instance, can you print a working adjustable wrench? If so is there a link to explain how this is done?
The supports and gaps needed between parts normally make it impossible to print useable assembled parts.
I would check Thingiverse, here is an example of one. https://www.thingiverse.com/thing:139268
To add a bit more details : the printer can print multiple parts at once, however these parts have to have enough clearance between one another (0.5mm as per https://formlabs.com/media/upload/formlabs-design-guide.pdf ).
The biggest challenge when printing assemblies is the supports. While you can print a screw and a nut together, the have to be oriented in such a way that both parts are supported independently (for example, you wouldn’t be able to print a sphere inside a sphere, if you get my drift). For 2-3 parts assemblies, depending on how the parts fit together, this can be fairly straightforward but for more complex assemblies it can be very challenging.
Makes sense, thanks!
I will have to start doing some experimenting.
Let us know how it turns out
