Dimensions
Hello,
I am very close in buying a Form 2 after printing with several FDM printers. One issue with FDM alwasy was dimensions. My question is, if I print a part with the form 2 which needs to carry a ball bearing with 16mm outer diameter, will it fit in the printed part right away, or do I need to scale the 3d data to compensate shrincage, or do I have to rework the part?
Thanks for helping.
Toto
what sort of fit are you looking for? what are the bearing tolerances?
Hello,
well standard bearings are H7 and I am looking for a slight pressfit or it should slide in with pressure of your fingers.
I expect that you should have no problem printing that feature as is, with proper orientation and support.
