Hello everyone,
I need to calculate the actual amount of powder used (the amount applied to the parts plus any waste) in order to determine the cost of the manufactured components. How do you handle this? Is there an Excel spreadsheet available? Are there any specific procedures or software programs that can be used?
Preform gives you an idea of the power needed for each part. If you load your models in you can right click on the model and select model properties. It gives an idea of waste for the entire print as well. Waste is largely dependent on how efficiently you pack the build chamber. With Nylon 12 packing densities around 25 percent and above, in my experience, allow you to run without accumulating excess used powder in sift.
It’s worth noting that you’ll lose powder to overdosing, sifting, blasting, spillage, etc and that isn’t included in the perform total. Running 24% packed builds at a 30% RR I’ve noticed a slow decline in our available powder. Upping the RR to 35% seems to have plateaued that. Makes sense that ~10% is lost to imperfect cleaning in the sift
