Hi everyone!
I just stay new owner of form3.
On the old display printer i adjust it by exposition time and almost catch few microns accuracy, quite similar HDT resin. on the FDM easy adjust flow(and do it before each critical printing).
but i confused, how to fix size problem on form3?
so, 1cm height, 8mm external diameter, 5mm internal diameter pipe, by fusion 360.
Printed vertically, 10,3mm height, 8,15mm external diameter, 4,65mm internal diameter.
generally was printed 7components device prototype,one pipe just example, and due all sizes out, completely cannot be assembled. all sizes out 0.1-0.2mm (all inner dimension smaller, outer dimensions bigger)
