Hi I work with Jewelry and was wondering if High Temp Resin would be better for Making a master mold of jewelry than Castable …
Say I want to print some jewelry that is relatively thin and then vulcanize mold it … would it be better to use castable for high temp for this?
Some pieces which need the 25 micron smoothness and would like to avoid casting castable in silver or some other metal before molding (avoid steps cleaning that up)
I believe that for vulcanized will be the best alternative I use the gray plus my mold and cold silicone I believe would be a better alternative because it does not retraction in the part and because it is easier to make the cut by being transparent.
