You can make a Vat out of PETG too, easyer to source and work than PC and kind of the same characteristics
I’ll post back the source files for the Form One vat once i get my hands on one.
In the mean time here’s a link for some Cad files shared by another Master, unfortunately he no longer has the STEP files and the other is designed on Sketchup
Will be a good starting point to a Open rebuild tho
Funny! Form2 has a chip, you know, for good or bad has been argued already. Unless you meant using the Open settings? The CAD for the Form2 is straight forward, a basic structure really.
The chip is not an issue. I got a 3D model of the tank as well.
The question is, what is the advantage? Making your own tanks? It saves you a lot of trouble to just buy a tank, use it up, replace the acrylic sheet with glass and recoat again.
Another option is to buy there LT tank. There suppose to last ten times longer. Which might make it more cost effective than re-coating an existing tank.
Nope, I don’t surf the Facebook group. And I am using a LT resin tank. I can’t say I’m having any issues with it. As far as I can tell it’s working fine.
