Form4 Elastic 50A discoloured in tank
I loaded a bottle of Elastic 50A into my Form 4 less than seven days ago into a brand new tank with mixer. I printed several models with great success and got my desired white/clear post-processing results. I sent another print this morning but noticed, while removing the model, that the resin was discoloured and yellow. Twenty-four hours previously, the print pictured came out transparent. Any ideas as to what caused the resin to discolour so quickly?
I’m on Form 3L so my experience may differ but :
My resin tank and prints always have a yellow tint before curing them underwater.
After an underwater cure the tackiness and tint are gone and my result look like your finished part on the third picture.
Good question @MurphKieran - We recommend to wash the parts as normal and then cure them. Wait 24-72 hours after you cure the part, and some if not all of that yellowing, should dissipate back to clear.
did the print turrned back to clear? I did quite a bit of elastic 50a in form 3 and now that I have form4 I just got back to elastic “flexible 50a v2” and the same all prints are yellow :smiley:
They tend to be yellow in the green state and then turn clear after curing.
I do have a similar issue with this, however I do use ESD resin as well so this might causes issues when washing it with the form wash bucket; I did find that leaving the cured “tacky” part underwater with no curing overnight, it becomes somewhat clear; not sure why that happens
