Form2 preform volume
I am designing parts to the max volume of the form2, but it is not fitting in the preform software volume. What is the design volume to fit in the preform software for the form2???
The Form 2 build volume is 145mm x 145mm x 175mm. If your parts aren’t fitting in one go, you should check out our tutorial on how to make things larger than your build volume :wink:
