Does anyone also have an annoying hum/vibration from the Cure L?
We have it in the office so it’s quite noisey.
It seems to be coming from the turn table/motor. When I take the glass table out, the noise disappears.
I noticed the center gear is 3D printed also, not sure how accurate that is or if it’s something else causing the noise.
Anyway to reduce this noise?
Thank you
Hi @Farnworth .
Thanks for reaching out, and sorry that we didn’t get back to you sooner. Although there is a small amount of noise generated from the Cure L during operation, I wouldn’t expect it to be particularly disruptive so we’d be happy to take a look. If you could please reach out to our Support Team with a video of what is happening, we should be able to help identify the cause of the noise and get some sort of resolution.
