I am trying to print this part on my Form 2 (these are FDM printed parts, at 0.3 mm). The shape is a flat, rectangular box sliced in two halves.
My first try using Draft resin resulted in this. The resin and the tank were both new, out of the box; I used a Form 2 Resin Tank LT.
Then, I tried using Applied Lab Work Gray in Open mode, different orientation. You can see how I got some layer hanging.
the bottom of the tank ended like this
I already cleaned the glass, the platform was flat, the mirror do not look dirty.
Any Idea what is happening?
Thanks!
