Failed Print - First Print with new LT Tank
Hi All,
I recently received a LT tank and wanted to start using it. The very first print failed, and there was resin adhered to the interior of the tank surface. I tried another, different print and the same thing has happened. Both times there has only been one small area stuck to the tank - near the very center of the build platform. My initial thought is that the build platform is getting worn down and the base is not adhering to the build platform in this location. I would love some feedback on what you think the issue may be.
Thank you!
