After uploading a job to formlabs 2 the printer makes some moves - and then “error code 58” appears. Nothing happens after thaht. No print is posible.
It appeared after connecting pronter with dashboard and updating the Preform. No error happened before that.
At least the error code seems to have reduced itself by a factor of 2… Can you try re-orienting the object in PreForm and re-uploading to the machine to see if that corrects this?
