Hello When starting a new print I get the following 2 error messages:
“Open cartridge vent”
Check build platform"
I printed one 15 ml print last night with new Clear cartridge and new rising tank. When I attempt to print today the two messages occur with every print attempt.
I;m also worried that the from button is stuck in the inner position. Because the printer is relatively new I don’t know if the button is a plunger type button that should be pushable, or if it is flat to the ring light and only buttons on the LED panel should be pushed. If the button should be pushable then it is STUCK?
I’ve also uploaded diagnostics in an attempt to get more support. “OrganicMallard” is the serial number.
