Enabling Custom Squish
We’ve been having some dimensional issues with our Form4B (material: BioMed Clear V1) at work and one of the settings that I want to change is the ‘Squish Wait’. But when ever I enable Custom Squish, without changing any other settings, the build platform makes contact with the bottom of the resin tank and causes a ‘debris in resin tank’ type error.
Has anyone else run into this issue with Custom Squish?
Hi @CCWP, can you confirm the values for the squish profile used? Is it a constant deceleration?
Squish values are Formlabs default Custom Squish:
Squish Deceleration: 500.0mm/s²
Early Layer Squish Height Cutoff: 1.0mm
Early Layer Squish Wait: 90.0s
Max Squish Speed: 60.0mm/s
Squish Wait: 22.0s
Thanks for sharing your settings! The issue you’re seeing is likely caused by the Squish Deceleration value being too high. Right now, 500 mm/s² is the default when enabling Custom Squish, but that value is more suited for a different squish mode.
For Constant Deceleration, a much lower value is needed. I’d recommend starting with 5 mm/s² and adjusting from there. If you still see issues, lower it further. If things are stable, you can try increasing it slightly for efficiency.
The rest of your settings look reasonable, so I’d focus on adjusting Squish Deceleration first. Let me know if this helps!
I turned it down to 1mm/s² and that worked! Currently tuning it to the fastest the machine can handle. Thank you!
You’re very welcome! I’m glad you were able to find something that works, and hopefully if someone has similar issues in the future they’ll stumble upon this thread :slight_smile:
@CCWP curious what you ended up settling on for this and why you wanted to change it in the first place? I’m troubleshooting something similar right now with biomed durable and I think I need to increase the settle time for the resin to flow back before the next layer.
Trying to do this with Tough 2000. Machine keeps throwing debris errors even at super low decel/speeds. Basically unable to get custom squish working. Any ideas?
Replying to myself here in case it ever helps someone in the future. Squish decel needs to be way lower than 1mm/s2. We started off with 0.1mm/s2 and then landed at 0.3mm/s2 as the highest it could go.
Interestingly at 0.1mm/s2 the Z accuracy is wack (greatly oversized by like 12% ish). At 0.3mm/s2 it seemed OK…but doesn’t instill a ton of confidence. Probably moving away from trying to use custom squish at all right now.
I wish that the “squish wait” parameter was just broken out as an editable parameter that works in conjunction with smart squish, because the wait parameter has a lot of beneficial effects, and clearly enabling custom squish is kind of buggy or at least very unintuitive.
What beneficial effects do you notice from squish wait? Also what viscosity are you trying to print with? If its Tough V2 its 2,680 cP at 25 °C.
Increasing squish wait helps a lot in cases where you have surface finish artifacts that are caused by geometry and print speeds
Maybe Squish Intensity could help? It still uses Smart Squish, but lowering the intensity slows down the printer motion, so you keep Smart Squish, just with gentler/slower motion i think
I had a different issue with lots of failed prints, but since lowering Squish Intensity and changing Post Expose Cure Wait to 1–2 seconds, I’ve had zero failures or surface artifacts.
Yes squish intensity also can help. I was testing both at the same time…they each have their own quirks for my application unfortunately but I’ll be choosing one of them soon.
I’m not seeing any print failures - just surface artifacts which is apparently caused by resin flowing prior to exposure - which is why post squish wait is an important parameter.
Curious what kinds of failures you were seeing?
I’m printing figurines. Mostly, sections of the model would suddenly fail mid-print. A chunk would stick to the tank film and the print would continue, leaving a hole or a flattened/missing section. Whenever that happened, there was always a flat cured-resin “pancake” stuck to the tank film.
I’m not sure what helped more, lowering Squish Intensity or adding Post Expose Cure Wait, but since changing both I’ve done around 50 prints, including models that caused problems before, with zero failures. The only downside is that prints take much longer now.
I described it in more detail in this topic:
Small miniature failures - Post Expose Cure Wait / Squish Intensity made a huge difference - #4 by pkwietniak
Ah I remember seeing that. Sounds like your issues are different than mine. My problems are caused by cupping regions that are vented but still create issues because of how fast the printer wants to print. Even with cup mitigation turned on, it’s not good enough.
The solution is similar though, printing slower - specifically waiting more to let resin settle before exposure is the solution…just need to decide whether lowering squish intensity is any better than custom squish (they both currently have some weird quirks)
