Hello Everyone,
I’m making jewellery models for Vulcanised Rubber Molding. Since I got my Form 2, I have been printing models in Grey V4 resin. The prints
looked quiet dull in grey and I wanted to try out some bright colors.
So, I printed a few models in clear resin and dyed them in IPA. Here are some results.
Please suggest me how I can improve.
Link to photos;
Thanks
That’s beautiful! Post a pix when you cast it.
You dyed it in IPA? With what? Never even thought about it.
A
Looks great! Would love to hear more about your specific dying process, concentrations, etc.
@AnnDavisStudio , in the meantime if you search the forums for “dye” and “iso” you’ll find some more information on others’ efforts, eg:
Did a few test dyes today on White V4 and Clear V4 with iDye Poly in Red, Black and Green, dissolved in Isopropyl. I ended up leaving them in the solution for around 4hrs. The clear dyed way better than the white, which seemed to be a bit patchy. Would probably be a lot better if the parts were suspended in a jar of the dye rather than sitting in a tray.
[DSC_2722]
[DSC_2736] [DSC_2731] [DSC_2740]
That sounded like a worthwhile experiment so I tried it with some white parts left over from the previous experiment. The results were considerably worse. These parts are shaped perfectly, but the splotches actually make them look misshapen!
[image]
Thanks rkagerer, missed that discussion. Thought it might be an acid dye but never thought of mixing it with alcohol…fun experimental day ahead!
