During a print the Form 3 sometimes stops and complains about a tank-cartridge mismatch. i.e. the printer thinks the resin cartridge has been changed mid-print and the current resin cartridge does not match the print job.
This is odd, since the resin cartridge has remained constant.
This has only happened to me for this one resin cartridge. It’s Tough V5. I’m guessing there must be a weak reading of the RFID tag. Around 5am it happened, and self-corrected. i.e. it misread the RFID tag, then correctly read it two minutes later. The same problem occured around 6am, and it self-corrected 18 minutes later. The same problem occured at 9am. I removed and reinserted the cartridge and it corrected itself.
Has anyone that has had this problem heard-back from Formlabs on this? IMO if a “smart” operation can’t be done reliably, Formlabs should let us override it.
